Hi all,
I explained to the Mrs. that the TFP method is the way to go and I dropped the cashola on a shiny new TF-100 test kit.
After the first run of my test kit it's clear (no pun intended) that I need to drain/re-fill about 50% of the water to lower my CYA.
So the Mrs. kinda flipped out and said "What? The water bill will be super high! Just go to a local pool store and see what they say." For some reason I have total faith in you complete strangers, and consider you all as my "local pool store".
That said, I'm at a bit of a crossroads here... I have a few questions and think she just needs some re-assurance that we're going down the right path.
1. The CYA test is indeed a bit subjective (as the instructions say). One of the goals of the TFP method is to save money, correct? So is it really worth draining/re-filling half my pool water based on the results of a fairly subjective test? Why is high CYA bad for swimmers again?
2. After replacing the water, let's say my CYA is finally down to ~50-60. (Is 60 okay? I'd rather replace the least amount of water possible.) I believe after the SLAM (about $24) I'll have to add a gallon of bleach every day ($2.99 for 121oz of 8.25% bleach from local grocer) until it stabilizes?
3. I think I remember reading somewhere before that local pool stores try selling a bunch of chemicals we don't necessarily need... I am all for trimming off the fat and just buying what I actually need! But if bleach is 8.25% Sodium Hypochlorite, isn't that only "8.25% of what I actually need?" And I'll have to add bleach to the pool every morning vs. throwing a puck in the skimmer that lasts a few days?
I know that the TFP method reduces guess-work and saves us money in the long run, but how exactly? Could you provide some examples of when and where going the "local pool store" route can go wrong? Maybe it has happened to you in the past?
Again, I have total confidence that everyone has done the math, compared the "local pool store" method (along with the cost of chemicals) to the TFP method and decided liquid chlorine/TFP way is the way to go, but I don't know how to communicate that to my superior.
This is our first pool, so basically everything is new to us at this point.
I've also read the Pool School stuff, so that was helpful.
Thanks a ton!!
-Gary
Thanks a ton!!
-Gary
