I found this article pretty accurate compared to most things I read about saltwater pools. The only thing I even found questionable was the statement that salt can degrade some materials. But they only mentioned metal, which I suppose could be true to some extent. I don't have any ladder or other metal items with which to confirm or deny.
At least they didn't mention breaking down stonework, which is the most common fallacy I see.
The Pros and Cons of Saltwater Pools
Would you install a saltwater pool instead of a standard chlorine option? Consider cost, comfort, and more—we've outlined seven pros and cons here.
www.bobvila.com
