- Jun 24, 2021
- 16,768
- Vinyl
- CircuPool RJ-60 Plus
pH rises the fastest when pH is low and/or TA is high. You reported TA of 300 before. Your reduction of pH reduced the TA. Aeration and high TA cause pH rise.
When you reduce pH with acid, you also reduce TA. When you aerate, or allow pH to rise, TA will not also rise, it will stay the same. You are making progress.
Continue lowering pH to 7.0 and aerating. Everytime you do, your TA will reduce. When TA gets to about 80, stop forcing pH to 7. Only reduce it to about 7.8 and it should be fairly stable.
What is the TA of your fill water?
