carlscan26 said:Are you still running your fountains and cleaner too? Hang in there!
chem geek said:You might be outgassing some chlorine from the aeration from the fountains, though usually that isn't noticeable. However, a small percentage of a large FC number as with shocking might make that noticeable. In addition to turning off the ozonator, I'd stop running the fountains and other aeration sources and see if your overnight chlorine loss drops. I'd say you are fairly close to being stable, but something is still making a higher chlorine loss than typically seen. Because of your higher CYA level, the higher shock level makes the "1 ppm FC overnight loss" rule difficult to achieve. If you get down to 2 or less, you're probably good, especially if at that point you let the FC drop down to 15-20 and the overnight loss becomes 1 or less.
Not high FC. However the test can be affected by cloudy water. From the extended test kit directions:izjay said:I also have a question regarding the CYA test. Does the high chlorine level affect this test in any way? I just want to make sure the last test (around 60) was accurate.
Very rarely, cloudy or murky water can affect the CYA test. To check for this, fill the view tube with straight pool water. If you can still see the black dot clearly, the cloudy/murky water is not affecting the test result.
linen said:Not high FC. However the test can be affected by cloudy water. From the extended test kit directions:izjay said:I also have a question regarding the CYA test. Does the high chlorine level affect this test in any way? I just want to make sure the last test (around 60) was accurate.
Ohm_Boy said:Question from left field - is there any chance that you have an auto-fill device on your pool which keeps the water level up?
izjay said:Ohm_Boy said:Question from left field - is there any chance that you have an auto-fill device on your pool which keeps the water level up?
No, I do not.
Bama Rambler said:Have you checked every possible place for hiding algae? Ladder, lights, and everything else in the water?
I would like to raise my chlorine level as high as possible. Can someone tell me what the highest I should go is?
Ohm_Boy said:In addition to the loss from killing organics, there will be some percentage of loss during the day to UV. As a percentage, the UV loss is greater at higher FC levels, so more of the higher levels are wasted during the day. I doubt that the higher levels are physically hurting anything, since this isn't a vinyl or fiberglass pool, but it would probably be best to stay around the shock/mustard shock level, from an economy POV.
