Ok, your FC is starting to hold now. At this point, test your CYA and report your result.
CYA is at 25Ok, your FC is starting to hold now. At this point, test your CYA and report your result.
Thank you for your response. I did make sure on the bleach I have been using. If I need to buy more than I have on hand I will take your suggestion on the 10% liquid chlorine from Walmart.You mentioned something about foaming. It was likely from the amonia / FC reaction, but it is worth mentioning that the liquid chlorine you get should NOT have any additives in it. Non scented, not splashless, NO chloromax technology, no polymers, no special stuff. The chloromax is known for making the water foam.
Best if you can get the 10% liquid chlorine from the pool section at WalMart. This seems to be one of the best way to get it. Just make sure that the correct percentage is used in the Pool Math calculator.
