Readjustment of ph?
peetvj
1
Johannesburg
Ph level is about 6.8.
Chlorine is at 0.3. Water looks milky green not crystal clear. Pool is 45000 litre? How much acid and Chlorine should I add?
Welcome to TFP! :wave: We encourage pool owners to download the PoolMath APP. It is very helpfull in assistting with chemical amounts required. Of course using a proper test kit is extremely important. How are you testing your water? Looks like you have an algae problem. For that we follow the SLAM Process. If your pH test is accurate, 6.8 is much too low. What is your current TA level?
Have you seen our Pool Care Basics? Lots of great articles there to help as well.
Reactions: Newdude and Bperry
SLAM process as mentioned above. You’ll need a reliable test kit that can measure chlorine using FAS-DPD which can measure chlorine levels over 10ppm.
