Hi-
I am concerned about accurately reading the the pH results on my K1000 test kit. The lower levels of pH listed (6.8 and 7.2) show that the tested water should be an organge-ish color, approaching yellow. My water just gets light pink, without a hint of orange or yellow. Is that normal? Should I assume lighter pink is the equivalent of lower levels of pH, even though the color is not at all like the color shown in the pH column of the kit?
I've been working to decrease the TA (it was 110, now staying steady at 90; all other measurements were within normal limits) in our pool by adding Muriatic Acid. The pH has gone down, as is supposed to occur, but it doesn't seem to get down to the orange-is yellow color that would indicate 7.0 as recommended. I'm wondering if I really need to keep adding acid (I've added a gallon already) or if low pH measurements sometimes show as light pink rather than the orange-yellow shown in the kit.
Thanks!
Thanks!
