I am testing CYA using the Pentair test kit with the vial that has a visible dot that slides up and down in the test sample. The instructions say to mix the chemical with the water sample and wait between 30 seconds and two minutes to read the results.
My problem is that when I take a reading at 30 seconds the result is 30ppm and when I read it after a minute or two the result becomes 35ppm. Which reading is accurate?
Mike.
Mike.
