We are having our in-ground pool re-plastered at the beginning of June and managing the startup ourselves. I've been reading the info provided by our contractor, as well as other info online (including the guide on TFP) and just needed some additional clarification.
Our pool is traditionally saltwater, but I understand we can't add salt for about 30 days. Around day 3-5 I need to raise the chlorine level to between 1.5 and 3 ppm. What is the best product to achieve this? I've read I can't use shock. We typically use Bioguard products and have some old SilkGuard Complete Tabs/Sticks I could use, but not sure how many.
Trying to avoid messing up the new plaster and have all of my ducks in a row before the work is done. I'm ordering pretty much every chemical I can think of so I can take care of any water quality issues ASAP and not worry about shipping delays on chemicals due to the pandemic. Here is what I'm ordering:
30,000 gallon pool. Being filled by water truck from local hydrants. Not sure what the quality will be, but our well water is pretty hard.
- BioGuard Pool Magnet Plus: 4 quarts (sequestering agent)
- BioGuard Balance Pak 100 Alkalinity Increaser: 50 pounds
- BioGuard Balance Pak 300 Calcium Hardness Increaser: 54 pounds
- Muriatic Acid: 10 gallons
- Some chlorine agent???
Anything I'm missing? Anything I'm way off on my quantities with?
After the 30 days I'm assuming we'll follow standard conversion to saltwater instructions like we did last year (dump a bunch of salt in and turn on the SWG).
Thanks in advance for any help and guidance!
