Hi team of experts,
I would like to rebalance my cyanuric acid from approximately 90 to 100 back down to about 40 to 50 maybe even 30.
My issue is that the pool is three months new...and I remember reading somewhere that you should not empty the pool at all in the first year. I don't necessarily plan to empty the pool but approximately 50% of it in order to reduce the cyaniric acid by approximately 40-50% based on the calculators I've used online.
What I'd like to learn from the experts here is what is the best way of going about it, and given the hydrostatic pressure around the pool if I should even do it.
Should I be filling it at the same time I have a sump pump running while it's being filled? Should I simply drain and fill back ASAP? So many questions on best practices.
any advice appreciated.
TIA!!
TIA!!
