Greetings, I have a now 15 year old gas pool heater that is giving me problems.
First, I had the hardest time getting the pilot to light-up.
So I cleaned everything up and now it lights-up and the flame is nice and blue.
I have tested the thermopile that sits by the pilot and it is working fine.
I have tested the the high temp switch by bypassing it and it is fine.
I have cleaned the exhaust which was full of dry leaves and spider web (actually thought I had found the culprit).
So, the pilot is on and everything ready to go. The thermostat is set at the highest setting.
Problem is: The second, the heater switch is flipped ON, I hear a click that seems to be coming from the valve, and everything shuts down, even the pilot light.
Additional info:
1- Yesterday, before cleaning and testing everything, I managed to start the heater. It lasted for 2 minutes then shut-off, even the pilot light.
2- I restarted the pilot light and managed to get the heater going for 2 hours. Came back to it and everything had shut down again, even the pilot light.
3- the whole heater part was taken off and was stored inside to avoid bugs and spiders to block the tubes (has happened before and fire caught in front of unit, triggering the high temp switch. I blew air pressure in the tubes prior to install anyway.
Thank you.
Envoyé de mon SM-G950W en utilisant Tapatalk
Additional info:
Thank you.
