Last year we had new pool installed with a Raypak 6450TI-E heat pump. I'm trying to find out if there are any options where I can hardware a remote controller to it and install in my house. I'd like to be able to raise, lower the water temp and also check on current pool temp. Obviously, these can be done at the unit itself but I'd like to avoid having to go outside every time I want to check on status, etc. A wireless system would be acceptable as well. I've looked online and found nothing. The only possible solution I've found is the "Heater Reader" but that system seems somewhat invasive.
