Recently purchased a brand-new Raypak Avia Pool heater and it worked fine for approximately 1 week after having it installed by the pool company. Unfortunately our pool timer failed the other day and I had to manually flip the switch on every morning to run the pumps, which got annoying. But even then everything was working perfectly fine. Had a licensed electrician come by to help install the new pool timer switch, which works perfectly fine as well as all the equipment connected to it except for the pool heater. After troubleshooting, I am noticing that I am constantly blowing the F1- 5 amp fuse on the main circuit board every time power runs to the unit. Must have gone through 4 fuses at this point. the fuse blows almost instantaneously as the power from the pool timer switch is turned on. the fuse will also blow if its powered directly to the main power line without being feed from the pool timer. I am stumped, so is the electrician. Called Raypak, new circuit board is not in stock. Warranty case started, but could not give me any specific dates on when it would be available. and the certified technicians in my area are at least 2 weeks out just to inspect the situation.
Has anyone dealt with this issue before and figured it out.
Is there any practical temporary pool heating solution that anyone is aware of for the time being, the YouTube video of a guy coiling a copper tube and connecting a regular pump then starting a campfire certainly made me laugh.
