Hello all, just opened my above ground pool for the upcoming pool season. When i flipped the circuit breaker on, the unit turned on. A few hours later, as i was working around the pool, I noticed the display was blank. (Pic attached). After flipping the breaker off and on a few times, nothing changed. I opened up the front panel, and checked it with a multimeter. There seems to be power to the unit. Also, I checked the purple fuse (pic attached)for continuity with the multimeter, and the meter did make a beep. (I’m a novice with all this electric stuff). Curious if anyone else has dealt with this or has any knowledge on what the cause may be.
