Hello! I am stumped trying to figure out an issue with my heater. Got a sensor fail code, so I swapped in a new thermistor. Easy peasy, right? I also cleaned the contacts on the board with QD Cleaner before I installed the sensor. Here's basically what I got: https://www.amazon.com/Flngr-009577F-Temperature-Compatible-Heaters/dp/B0B7H8SVJJ
However, now, when I go to turn the heater on, within ten seconds or so I can watch the "Water Temperature" readout on the LED screen climb rapidly and smoothly, all the way up to 190ish degrees. It stays there, and slowly comes back down to temperature once the heater turns itself off due to the apparently-high temperature.
I have tried turning it off/on, waiting a while, resetting the heater to factory defaults... nothing seems to be working to fix this problem. The heater behaves normally other than this incorrect water temperature reading, so I'm inclined to think it's still some problem with the thermistor. I really don't think I ordered an incorrect part. I don't know of any way to calibrate this, or have any idea on next steps forward to troubleshoot. It's not a very complicated machine, so I'm wondering just what might be causing the actual problem. Any suggestions would be much appreciated. Thanks!
