In a normal winter we simply turn on the freeze protection and forget about it. If we have a freeze it is never for more than a day or two.
We are in a rare freeze. It has been below freezing for about 48 hours now. Today the wind comes with more precipitation and then we sink to teens and single digits for Sunday and Monday. We are getting more snow later in the week - we will not be thawing out for awhile.
Here's my question: With the freeze protection we were getting a low flow warning and the water level of the spa dropped to just below the tile. Therefore the water no long came over the spillway. I read on another thread here that this is likely because when the freeze protection switches from pool to spa every 15 minutes the valves don't close quickly so the water level slowly lowers over time. We have a heater that we ran overnight because that is what the neighbor's pool guy did for them. We also have tarps draped over the pipes and equipment.
Reading that the heater is not necessary. Reading that leaving it in Freeze Protection Mode is enough. But is it ok for the water in the spa to be low? will it continue to get lower so that it is below the jets? See photo - we are concerned that if the spa doesn't turn on every few minutes that the pipes will freeze within the walls due to the fact that is a a raised spa. Should we turn off freeze protection mode and manually switch the pump from pool to spa every few hours? Should we run the pool enough to make sure the water goes over the spillway? Are we over-reacting because we have never seen single digit temps LOL!?
Thanks for the advice!
Austin, Texas
SWG; Pentair equipment, Easy Touch Panel, ScreenLogic App
Austin, Texas
