Sorry I can understand why this is confusing. My at home tests are conflated with pool store tests. I should start using Notes to indicate the differences in the log.If the TA rise is from calcium carbonate from the plaster, you will get the same ppm increase in calcium hardness as you get in TA.
So, monitor the CH and TA to see if they rise by the same amount.
If they do, then that points to calcium carbonate.
How did you get an increase of 60 ppm CH in one day without adding calcium?
How did you measure a CH of 377?
The 9/9 reading of 377 is from my pool store test. The previous CH test was on my Taylor test on 7/30 was 450. The 430 reading on 9/10 was also my Taylor test. The pool store always shows me with lower CH than what my test reveal at home. If you ignore the store test (377), a drop of 20 CH in about 1.5 months seems reasonable especially since I had to pump off about 8 inches of water due to Hurricane Ida.
I also have a difficult time discerning the blue endpoint of the CH test even when using the speed stir. The transition from red to blue is very gradual and really looks more purple than blue most times.
I will be testing pH, TA, and CH over the next few weeks and I'll post my results.
I can't thank you enough for your contributions to this discussion. I'll do whatever it takes to get this thing right so I'm here to learn.
