Hi all!
I am installing an IntelliFlo VSF to replace the old filter pump. I had my electrician over to discuss the electrical situation, as I need somewhere to house the Pentair PA 220GF for the new pump. The old pump ran on an Intermatic timer. Since I no longer need the Intermatic timer to control the new IntelliFlo VSF, the electrician and myself decided that the simplest solution would be to replace the timer with a spa type box that will sit in the same spot and house the GFCI breaker for the pump.
Only problem is that the spa blower is very close to the timer, as you can see in the picture I provided. Installing a slightly larger/taller spa box in that spot will likely have the box and the spa blower touching.
So, I am wondering... Is it possible for me to raise the height of the spa blower 6-10 inches higher by extending the PVC standpipe it sits on? That would make space for the taller spa breaker box. Instructions indicate that the blower needs to be a minimum of 12 inches above water level. I see nothing about max height for the spa blower. What do you think?
