R-0012 Reagent dropper size wrong!!???
PoolUmp
68
Bakersfield/CA
Just a public service announcement. When I ordered my TF-100 refill kit, the dropped on my R-0012 was the wrong size drops. I hope mine was an isolated case, but just giving folks a heads up. I knew something wasn’t right when I ran a full panel, and one of my numbers was WAY off of normal!
PoolUmp
68
Bakersfield/CA
Hardness test, for clarification
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
The chances of the dropper size being incorrect are remote. The precision of the hole size actually has very little to do with the size of the drop......it is the spherical shape of the tip that allows the drop to form through surface tension and then fall off the tip by gravity. The supplier of those tips doesn't make any other size and they are ordered in large quantities.
How do you know the CH test was incorrect?
What was the result of the CH test?
We'll help you get it figured out but, I promise, it will not be the dropper tip.
Post back and give us a bit more info, I think it can be solved pretty easily.
Reactions: setsailsoon
PoolUmp
68
Bakersfield/CA
I switched the dropper to the one on my old bottle of same reagent, and fixed it. I promise you, the drops were smaller. I can mail it to you so you can see for yourself.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
Better yet, email TFTestkits.net and they will send you a couple of new ones at no charge.
PoolUmp
68
Bakersfield/CA
I know because I test my pool regularly, and got a vastly different reading with the new reagent. Then switched tips, and it was back to normal. I’ll test it again right now
