Hi all,
I had a rough introduction to algae last year and that's when I discovered TFP and the SLAM method. It took me a bit to get the hang of it, but I managed to get my pool water back to crystal clear again.
I've been maintaining my pool clean all through the fall, winter and spring with no problems but in the past few weeks I've noticed that I'm getting an algae blossom once again. I had been noticing that the water was not totally clear for the last few days so I did a complete test.
My levels on Friday were:
So a high FC level but on target with my 100 CYA. (I don't know why it went from 50 last summer to 100 this summer when I've only been using chlorine pucks.)
On Friday evening the water was even more cloudy:
And you could even see a film of "dust" on the surface:
I skimmed it with a white cloth to see what it was and:
And once the filtration started working I could see on the skimmers the dreaded green muck
So with no time to loose, I started the SLAM process before the situation escalated and I brought my chlorine level to 39 and filtration 24/7.
Water looked much, much better on Saturday and on Sunday it looked like this:
Yes, there's water in the pool
I stopped adding bleach on Sunday evening and I hope this killed the algae. I know I should run a overnight test to see if I'm losing chlorine, but I ran out reagents for my Taylor K-2006 on Sunday morning and I need to get replacements. (Reagents vanish when you have to get to FC 39!) But I think I comply with the other two conditions of the test, right? I can see the bottom and the water looks clear
So I want to thank everybody for all the knowledge shared in this forums that has helped me to do such a quick turnaround for as little as $15 in bleach.
Next steps will be to adjust PH levels, but my question is: what's the chlorine level I should get for the PH test to be reliable? And then I will need to lower my CYA level, but I'm going to need the reagents first.
Any more tips?
Greetings from Barcelona!
Any more tips?
