Hello-
This is my second season on this pool. It's brand new, built last June. Closed and opened by builder. Salt/Cartridge filter/Vinyl/Coverstar autocover/~33k gallon (20 x 45 with 6' sunshelf). I'm in the Milwaukee area.
This thing has been crystal clear all last year and this. I've been real happy with it and it's been hands free. The only issue I have is the pH tends to rise "quickly", which, I realize, I actually have no context for what is normal. Basically, I'm adjusting weekly. For instance - this last Saturday (4 days ago), pH was 7.6. Added acid to get it to 7.3. Right now, 4 days later, pH is back to 7.5. I've added over a gallon of acid this month, and I haven't used it much in May (I'm in Wisconsin remember).
Salt - 3300 ppm (avg)
Chlorine - 1.5 ppm (I have the standard Rainbow 78 test kit - it just gives me a chlorine number), generally correlates to a 680 mV ORP reading.
TA - 100 ppm
CYA.....0ppm
I know. I asked the builder about it. His response was, if you feel like you need it - add it. He's never used it in his own pool, or pools he manages, and doesn't have a problem. I'm probably going to not add it unless I start to have an issue. He has just advised me to keep pH in range, keep chlorine in the 1.5-2 ppm range, TA in the ~100 ppm range, and leave it. The pool has been nothing but crystal clear ever since he built it. I don't know if the lack of CYA is affecting the acid rise or not.
I just wanna know - is the pH rise rate normal, or not? I don't have an issue adding a few pints of acid a week, I just wanna know if this is expected.
TA - 100 ppm
CYA.....0ppm
