Hi all,
First question is CH test. In the Extended Test directions (Calcium Hardness - Trouble Free Pool) it says to add R-0012 one drop at a time "until the color changes to something more or less blue". Mine goes more or less clear at about 40 drops, and starts to take on the faintest hint of blue at about 50 drops. Am I dealing with fading endpoint, or should I take my reading at the point when it first turns clear?
Second question is about which shock level I should use. I'd been dealing with a lot of yellowish gritty silt-like substance along the walls and floor of my pool, and especially in the crevices where the wedding cake stairs meet the walls. Thanks to a comment by @mknauss on somebody else's topic, it finally occurred to me that I'd probably been keeping the chlorine levels at just the right PPM to keep algae only "sort of" at bay. I've been getting professional pool service once a week, but my pool condition kept getting worse, so I finally decided to get involved. Got a Taylor test kit, Pool Math app, and started SLAMming Thursday of last week. It's only been 5 days, and my pool already looks significantly better, so that tells me it was probably algae that I intercepted before it became a major problem. But there are still trouble areas around the stairs and in the skimmer openings. I've been using the 16 PPM liquid chlorine SLAM level recommended for my CYA 41 PPM, but then followed a thread and came across this chart: Chlorine/CYA Chart which suggests if you're dealing with yellow or mustard algae, that you should use a chlorine shock level of 24 PPM for my 41 PPM CYA. Based on the photos I've provided, is the 24 PPM Yel/MstrdShock value appropriate for my pool's condition, or is that only meant for more extreme cases of algae?
Thanks for your insights!
