Hi- I am trying to help a friend regarding his new pool build. As my pool plumbing/pump configuration is different (2 pumps, 1 heater, solar panels), I am looking for some clarification on general heating/water routing for his configuration.
He has a spillover spa, a single pump, and a single large new electric heater/chiller (which is plumbed in, but electrical not hooked up yet). He is looking to plumb in a SECOND heater (an old propane heater) to independently heat the SPA. I believe he can do this all with his single heater, but need some clarification:
1) I assume during normal operation (spa spillover), he can set the big new electric heater to something like 84 degrees, and it will heat both bodies of water.
2) I assume that when he wants to use the spa, he will need to set his valves to pull water from the spa, and return water to the spa (effectively taking the main pool body of water offline for filtering), and can set the heater to something like 100 degrees. I am also thinking he may need to lower the pump speed, since he is effectively now only filtering/heating a small body of water.
3) Once done using the spa, he then needs to set the valves back to "spa overflow" operation, and sets the heater temp back to 84 degrees.
4) I assume his heater has 2 set points (one for POOL, and one for SPA).... my Hayward gas heater does, so perhaps this is standard?
If my statement above are correct, he can have his pool at 84 degrees, while having the spa at 100 degrees, without the need for a second heater. Even if he had a second heater, he would need to still perform the valve manipulation.
Is my logic correct here? Is this how things operate with a single pump, a single heater and 2 bodies of water (which can be made into one body of water, i.e. spillover?)
Thanks!
Thanks!
