There’s a little manual switch that says on1, off, and on 2. It was set to off. That explains that. I switched it to on 2 and now it’s pointing toward the pump
Changed from so to pool and the return valve moved as you would expect 180 degrees. The return valve did nothing
Looks like your intake actuator is drawing from the spa. Flip the toggle switch to the other side.this is a picture in pool modeView attachment 545483
It does seem the section valve needs to only turn 90 degrees. Is that an easy adjustment for me to make or do I need to get a professional?
So when it was in the spa mode (correct spa mode) the returns were pouring into my spa as expected but it was basically empty.....
