Good day everyone,
Now I use liquid chlorine to treat the water. I have been doing this for two years now according to the TFP method and it works fine.
However, I'm thinking about installing a SWCG and I'm looking into it. Now I have some questions and hope you can help me.
1. You have SWCG that measure Free Chlorine, ORP and Redox (is the same if I’m correct) and where the installation can be set with a percentage.
The IC40 seemed correct and simple for my setup to install, but in Europe it is not easy to get.
Since I have pretty much everything from Astralpool, I looked on their website first and notice a lot of variety.
The installation that measures free chlorine is expensive and someone also said that such a sensor should be seen as a consumable. Furthermore, it only measures up to 5 ppm FC. If your CYA is 80, then you need an FC of 6. So, this option is out.
ORP is not recommended here on the forum. A colleague of mine has such an installation and his problems seemed familiar to me from what I've read on the forum.
Now I found a SWCG on their website where the production can be regulated in steps of 10% (0-90%). So, this is preferable if I understand correctly?
2. My pool is 62 m3 (16K US gal).
The SWCG I have in mind is good for 120 m3 (32k US gal) above 25 Celsius (77 Fahrenheit), 140 m3 (37k US gal) between 16-24 Celsius (61-76 Fahrenheit).
This should suffice or do you recommend its bigger brother 160 m3 (42k US gal) above 25 Celsius (77 Fahrenheit).
I have a single speed pump (2 years old), I am not going to replace it for that reason. The flow is 16 m3/hr (4200 gal/hr), the SWCG for 42K US gal needs 8 m3/hr (2000 gal/hr). So, it shouldn't be a problem in my eyes, except for a slightly higher electricity bill compared to a variable speed pump?
3. The first option makes Cl2: 24 - 30 gr/hr (0.84 - 1.05 ounce/hr) and the second option makes 31-40 gr/hr (1.09 -1.41 ounce/hour).
How many ppm is this? In the summer it can be the case that I use 4 ppm.
4. Water balance
In the instruction book they recommend 5gr/l salt, which equates to 5000 ppm.
On this forum I read the following:
Second adjust CYA to between 70 and 80. The biggest mistake that many SWG owners make is NOT having enough CYA in the water! This can create a lot of problems like high acid demand, algae outbreaks, cloudy water, or early cell failure.
Adjust your Total Alkalinity to 60-80 ppm. (This is IMPORTANT!)
Adjust your pH to 7.2-7.8 and not any lower. Monitor your pH and when it climbs to 7.8 add acid to lower it back to 7.2 – 7.5 (This is also IMPORTANT!)
Adjust Calcium Hardness to 350 ppm for plaster and fiberglass. In any case it should not be much above 400 ppm, or you are going to have to keep close watch on your pH to prevent scale buildup.
My TA prefers to be around 50ppm and sometimes even 40 (I always boost it back to 50). Tried getting it to 80ppm but ended up lowering my pH and thus my TA. At 50 ppm it remains the longest stable.
My pH climbs from 7.5 to 8 in two weeks after I added muriatic acid (about 0.3 Us gal). This is pretty much the whole year through the same.
Will the water in my pool react/behave differently than the last 2 years, by means of salt and higher CYA?
Do you use a muriatic acid dosing pump to keep the pH between 7.2-7.5?
I have the feeling that my consumption of muriatic acid will skyrocket and will also have to add baking soda more frequently if I follow the suggestion to keep it in between 7.2 and 7.5? Or should I keep it in between 7.5-8?
Also, in the same article it says:
Calcium hardness should be brought to 350 ppm. In any case it should not be much above 400 ppm or you are going to have to keep close watch on your pH to prevent scale buildup.
On the TFP website I see also the values below.
ACCEPTABLE MINIMUM: 250-350
IDEAL: 350-550
ACCEPTABLE MAXIMUM: 550-650
Where do you keep your CH at?
Many thanks in advance.
Regards,
Dominique
4. Water balance
IDEAL: 350-550
Regards,
Dominique
