Questions about air in the lines
Ravaloft
7
Cypress, CA
Forgive me, I’m limited to posting from phone for now.
Does this look like too much air in pump? I realize this is difficult to see. All equipment is actually in shade.
Some of my return jets don’t have pressure. This is a picture of my pump and quick video showing what’s coming out of the most powerful rerun jet.
The other jets barely have pressure and send out fatter(?) bubbles.
This looks normal or should I look into maybe re-priming the pump?
Skimmer basket is clean and all looks normal there. Water line is good too
Air bubbles out of the returns are due to 1 of 3 things:
1) SWG, which you do not have
2) Solar when pressure gets too low and the VRV opens allowing air into the lines. - not normal, usually due to a dirty filter
3) Air leak in the suction side of the plumbing. - not normal, usually can be fixed by lubing pump lid o-rings and drain plug gaskets
