I had a few questions on the exposed plumbing portion of my ‘77 pool. I’d like to relocate the equipment a little further away from pool and trying to educate myself on the layout. The equipment is a simple pump & sand filter with a valve to turn on/off an aerator, one skimmer
Anyone have insight on the purpose of the two old gate valves? The pool was apparently set up for “whip” style cleaning, there are 4-5 areas that look like a mini return jet. Think one of these adjusts the flow to the whip return piping? What may the other
The piping with the offset I presume is from the skimmer to the pump? Any idea why the offset might have been used? Likely an install error?
below pic is if skimmer/piping & equipment is behind white wall area, other pic is detail of piping
