I need to do some partial water changes to correct a high CYA level. I’ve owned above ground pools in the past, but this pool is my first in ground. I have 3 return lines. One for the main drain, one for the shallow side skimmer, and one for the deep end skimmer.
The deep side skimmer valve is stuck in the half on position as the butterfly handle broke off this spring. Does that mean I can’t drain down beneath the skimmer level when doing my partial water change? My main drain works great, very high flow, so even if some air leaks from the deep side skimmer the pump shouldn’t run dry as the main drain will keep it going? Opinions? The cost of having someone come out to replace the broken valve is more than I can manage right now. We had a kitten who needed emergency vet care this weekend, it’s blown my budget right now paying the Vet ER.
thank you!
thank you!
