We are almost to the end of our pool deck additions/renovation. We added on 3 separate concrete slabs to make our pool deck larger. Two of the 3 slabs had oklahoma stone laid on top and the 3rd section will have "kool deck" to match the older deck that it is adjacent to that had kool deck already. The contractor said that in order for the new slab (with the newer kool deck) to match the older deck, he would have to spray the kool deck on the new one let it dry, then come back and pressure wash the old deck, then come back with a colored sealant on both the old and the new parts so it will all match and be the same color.
I'm not familiar with any of this, so I was wondering if this Kahlua Cream (the sealant color we chose) sealant would be the right way in going about finishing the deck? From what I understand, this sealant seams like it would be painted/coated on the deck, but my original kool deck is very textured and I think that adding this sealant would take some of that texture away and make it overall a little more smooth because it would fill in a lot of the little dips. Would it be better if he just sprayed new kool deck on the entire deck (both the new and old portion) and not use this colored sealant? Our current kool deck now feels is like concrete and there is no coating or paint on it. Not sure if the colored sealant would be "taking a shortcut" as opposed to just spraying the entire deck again and not sure if you can spray over the original kool deck with another application of kool deck? I read somewheres that it has to be sprayed on freshly cured concrete in order for it to adhere properly.
Below is the sealant he plans on using, would this be ok?
http://www.sgm.cc/html_Pool/Contractors/decorative_concrete_finishes.html
