I have an automatic suction side cleaner with its own side port. I leave this in the pool all the time so its running always when the pump is on, I have the three way valve usually half open. My question is and I've always wondered should I completely shut off the main drain or have the main drain pulling some water. I have a float valve at the skimmer to control flow between skimmer and main drain. I usually have this set to mostly just to use the skimmer to get get good surface cleaning, sometimes I close the flap slightly to get maybe 25% at most coming from the main drain becasue I am concerned about getting good water circulation and turnover, but closing it much more, say half way and my skimming action is minimal. Since I have the automatic cleaner running all the time when the pump is on pulling water from the bottom am I ok to set my float valve to just pull water 100% from the skimmer and nothing from the main drain? FYI The valve at the equipment pad for the cleaner is open about half way.
