Background Details
Our pool is currently under construction and as per our contract, following items are included.
1) Intelliflo 3 VS Relay pump
2) Superflo 2 HP pump - for water feature
2) Pentair 400K BTU Heater
3) Pool lights - Intellibrite (pool and spa) + Microbrite (tanning ledge)
4) Water feature (back wall)
On the contract, control panel is mentioned as “Controlled by Pump” and remote control as “Screenlogic WiFi”.
Contractor is now recommending us to add an upgrade of Intellicenter control panel and mentioned with screenlogic we can only control the pump, pool/spa lights and the bubblers. For the rest of the automation (water feature and spa heater), its manual.
During the sales cycle, they mentioned that all the pool features including water feature and spa heater can be controlled by Screenlogic wifi app on our phone.
As per our research, Screenlogic is an add on module for Easytouch control panel so we thought they will be installing Easytouch control panel by default. According to them, we are not getting "EasyTouch" control panel since there is no mention of that in the contract.
Questions
P.S : We are assuming that they missed adding the Easytouch control panel in the contract so they are now pushing hard to upgrade to latest control panel.
Questions
- Can Screenlogic WiFi be connected directly to the pump or Easytouch system is required in order to use Screenlogic WiFi?
- Can Screenlogic Wifi enabled in the main pump can give access to all the features in the pool through phone app?
- What control panel is installed for your pool? Do you have access to all the pool features through your app?
