- Jul 10, 2021
- 59
- Plaster
- Hayward Turbo Cell (T-CELL-5)
My Quattro cleaner (see sample photo below of what we have) works and picks up leaves, etc... just fine....almost.
However, given we have lots of pine trees behind our back fence so wind blows loose, finer debris into the pool regularly, this is what we really need the cleaner to handle because it accumulates daily, depending on the wind, etc...
Problem is I've noticed when it comes to this finer debris, the Quattro appears to be spewing some of it back out into the pool after sucking it up. If it is spewing this visible debris back into the pool, this means it probably is spewing the sand and finer stuff back in as well. When checking the basket, some stays in the basket, but that is probably because larger debris begins to accumulate and prevent the smaller stuff escaping, but if we start with a clean basket and there is nothing but the small debris stuff in the pool as described above, the job it does is subpar.
The unit is over 2 years old now and I've only noticed this in the last 3-4 months.
Any thoughts on the issue?
Much appreciated!
Pat
Much appreciated!
Pat
