Noob Here.
first time opening a pool so i'm reading and learning before i begin.
I want to vacuum out the bottom of the pool. I removed the skimmer cover, pulled out a jug of antifreeze and notice a red rubber hose going in the 2 smaller holes at the bottom of the skimmer.
Is this hose installed during the winterizing close out process? Can i just pull it out? It moves easily when pulled from the hole closer to the pool but is stuck on the hole closer to the pump.
Secondly, what pool instruction books would you recommend for a beginner to start with? TIA
