Hey, another new Vegas valley resident to the forum. My old stomping grounds. Welcome to TFP!
So, let's go over some things in an effort to get you back on track:
- You HAVE to cut the cord with the pool store and their testing. Accurate owner water testing with a TF-100 or Taylor K-2006C is priority #1. Store testing is often flawed, advice off the mark, and products overpriced. I highly recommend the TF-100 (link in my signature). Get the speedstiur as well if you can.
- Sometimes our FG pool get a dark ring around the waterline I call a "scumline". Does it seem gummy and hard to rub-off? Have you tried using a Magic Eraser to gently get it off?
- Your pH is too low of course. The soda ash might get it back up, we'll see.
- How are you chlorinating the water? Are you adding liquid chlorine, regular bleach, or some other packets?
- Maybe post a pic of the discoloration you are seeing, and maybe a pic of your equipment pad as well.
- Make sure to read our
ABCs of Pool Water Chemistry. Also read/save those Vital Links below in my sig. You'll use them often.
We'll do what we can to help. Thanks fo posting.
