Pump won’t prime
swmasson
9
Texas
My neighbors pump won’t prime, water levels are all good but there’s a lot of gargling noise and the pump isn’t filling up, the filter pressure is low and fluctuating… There must be a small leak somewhere as the ground under the equipment is a bit wet…
Any ideas on how I can figure out the problem for her?
Thanks
mknauss
43,985
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
A pump not priming is nearly always either a suction side leak, plugged suction line, or low water level in the pool. Be sure to check all those items.
Reactions: swmasson
swmasson
9
Texas
Thanks for the advice, I’ll check it today… Could a small drip leak cause this to happen? Water level is good…
mknauss
43,985
Laughlin, NV
Fiberglass
On the suction side it will normally only leak when the pump is not running.
