It's Intelliflo, correct?
It can work in stand-alone mode without being connected to automation.
Do you have automation?
If yes, what automation do you have?
If you have Pentair automation, you should connect the pump so that the automation can control the pump.
If you have other automation, like Jandy or Hayward, it would probably have been better to use a compatible pump from the same manufacturer.
