I have a Jandy Aqualink RS 6613/6614 control panel that is scheduled to come on HIGH speed for an hour, and then drop to LOW speed for the rest of the day.
Pump is a Pentair 2-speed 2hp
Since the last rain 4 days ago the pump is only working in LOW, even though the outdoor control panel and indoor wall display says that it's in HIGH.
There is no HIGH from service mode
I live in the desert, so it hardly ever rains. But when it does something always seems to get temporarily stuck. (HIGH only, LOW only, ON/OFF flakey...) It usually goes back to normal after a few days. The inside of the panel is not wet.
Sometimes in extreme humidity I have witnessed this also.
I'm no stranger to replacing the pump relay (Zodiac R0658100 3HP) in the past.
The pump capacitor was replaced 9/2019 Correct Capacitor Size?
Is there a way to test a relay in or out of the unit?
Why would these systems be so affected by weather?
Is there something else that I should be looking at as the cause?
So where do you think the problem is?
