Pool Details
17k, 6 returns/1 bubbler, SWG, Inteliflo VSP. North Texas with 100° F for a month and a half.
I had been running my pool fast at 3000 RPM for about 12-14 hrs a day with SWG at 65%. Then I got my electric bill.
I'm experimenting with speed, SWG settings, and run time to hopefully maintain 3-4 FC with minimal chlorine supplement.
Currently I'm at 1700 RPM with SWG at 90% for 11 hrs/day. This is not maintaining my FC very well but I do need to bump my CYA because it is at 40 and TA is at 110.
I'm seeing champagne bubbles out of 2 of the closest returns. Searching on the forum it seems this is unavoidable as it is due to the SWG. Is this OK?
The pressure gauge on the cartridge filter housing barely registers anything. When running the pump fast it would hover around 10 to 12 psi.
Do I need to pick the pace up a bit to build more pressure?
I know i've seen some of you say you run your pump really low. Just curious to what others are doing.
