Pump settings.
veganbaby
5
Texas
I tried searching the forum but couldn’t find anything. I have a few questions. We switched over to a Jacuzzi VS pump. We lost the manual. Can someone explain to me what each of the timer name means? I understand backwash. But the rest I don’t know. They just seem to be redundant.
Whirlpool, high speed, filter low. Low filter, maximum, minimum, , spa, edging, cooling, heating, mist, feature 1, floor cleanser gas heaer gas, pum, fountain
Spill pump, spa jets, solar,
Cleaner, clean,cleaning, sprinklers ,water slide waterfall water col water fear.
I would like to have a general idea of what they do so I can use my pool equipment to it. We have a Polaris that sweeps the floor, a vacuum that we hook up to the skimmer part and manually vacuum, and I just ordered a pool cooler that will hook up to the jets to cool the pool.
Also what are the best settings for a inground 30k pool. We live in DFW area of Texas where the highs has been 100 and lows 80s in the summer. We have mild winters where we get down to below 30 maybe a total about a week. Fall weather is like 80s. I was just wondering if we should change the pump times during the winter. We can set the pool pump to change timers. I have googled these mercilessly and just can’t find solid information of which is best. Thank you.
Welcome to TFP.
You have the 1.85 HP pump or the 2.7 HP Jacuzzi VS pump?
Run each of those selections and note what RPM the pump runs at and then post it here. Then we can help you select which ones are useful for you.
Thank you for the welcome. I have the 1.85 one. As far as RPMs it allows me to choose them. The RPMs range from 1000 to 3500. Factory setting has them all at 1750.
