Hi everyone, I currently have a single speed hayward tristar that I would like to replace, with a variable speed for much better efficiency / lowest power bill / less noise.
I am currently running everything through Omnilogic by Hayward, and it is doing okay. The pool company offered me two options:
Hayward HCP 2500 (not 950) - should be able to integrate to my Omnilogic control board well
Pentair IntelliFlo 3 VSF 011075 with OmniHub Converter Daughter board - needs the daughter board to connect to omnilogic
Price-wise, Pentair option is slightly more because of the additional board purchase.
I read through everything I can find here and on the internet, and keep getting conflicting info. We would love to be able to adjust everything for this high end variable speed pump, flow rate, RPM, anti freeze, etc. I do not mind using another software on my phone to control the IntelliFlo, but I do not know if that is an option. With the daughter board, would I be able to do that? I really want to avoid just have four speed control, which defeats the purpose of VS.
We have a spa with bubbler, a heater, two fountain features, 18k gallon salt water concrete. Current pump is 2.5 HP, this is why we are going for the higher end pump.
I read that Pentair has a much more robust design with longer life out of it, so I am leaning towards it. Plus, the pool company only offered me the commercial Hayward option rather than their 2.7 HP tristar VS950, so I do not know if that's a bit worse than 950, not much information about it.
What would you guys recommend? Which one might be a better option, or even find someone that can install Hayward Tristar VS 950?
Thank you all in advance! The more I read online, the more confused I get...
