- Apr 22, 2021
- 117
- Plaster
- Pentair Intellichlor IC-40
Hi,
I have an EV electrical rate plan with different rates being charged based on time of use. 11pm-7am ~2c/kWh daily, June-Sep 2pm-7pm ~25c/kWh and ~8c/kWh for all other times.
Currently, I run the main pump at night 11pm -7am daily (4 hours for skimmers, 4 hours for main drains), I “refresh” the spa for 30 minutes twice a day at 6am and again at 1:30pm. The Polaris runs for 3 hours nightly.
As the temperatures are now increasing, I will start using the IntelliChlor again, adjusting the percentages for chlorine generation as needed.
I’ve read numerous recommendations to run the pump 24/7 at a lower speed. I’m running the pump at night. Does the approach I’m taking raise any concerns (including the hot summer days in the 90Fs)? Any adjustments to the above scheduling I should consider?
Best regards
Tony
Best regards
Tony
