Hi, I am having a problem wiring my Aqua Ultraviolet 40 Watt UV light, 120V to my relay that has an Intelliflo VS 240V, 16A and Intellichlor 240V 7.5A.
I have a 40A GFC breaker that I am using for the pump. I am using a 120V outlet (non GFCI) that I will be plugging in the UV unit, 120V, 0.48A. So far I do see that I am getting 120V to the outlet. BUT when I plug in a standard power drill (to test) the breaker trips. I have one wire (black) from the outlet wired to one leg on the relay and the other wire (white) connected to the common bar in the panel. I don't want to plug in the UV unit until I know I won't burn my bulb. Please let me know if anyone has a UV set up and how you wired it.
Thank you,
Thank you,
