Hi Guys,
I'm new to this forum and also new pool owner (installed right before last fall).
I have a 14X26 inground with a Hayward salt system and Hayward filtration system.
I replaced the pump that came with the pool (Hayward Super Pump 700) with a Pentair SuperFlo VS mainly because of the noise and also to reduce the electricity bills.
I had to change some of the plumbing when replacing the pump so I also added a FlowVis flow meter.
The trouble I have now that I didn't have last year is that when I go and vacuum the pool I can't do it for a long time because the pump seems to fill with air pretty quickly so I don't have much suction left after only a couple of minutes.
I fill my vacuum hose before doing it so there's no air in it.
When I go and check the pump, there's only a bit of water in it, like not even half the basket full.
I then stop the pump to empty the debris but the water seems to get even lower and I can hear air bubbles.
When I close the cover and start the pump, it's super long (couple minutes) before the motor primes the system.
I tried to backwash and rinse a couple of times (seems to fix the problem) but then it does the same thing the next time I vacuum.
I don't know what's going on and it's getting frustating.
Can it be the FlowVis meter that's causing trouble since it's also acting as a check valve ?
Piping from the flow meter goes into the heat pump.
Bubbling sound :
Priming of the pump :
Pump when vacuuming :
Thank you !
Jo
Bubbling sound :
Thank you !
Jo
