My pool pump is getting louder and louder and I think needs replacement. It is probably the motor making the noise so I might be able to get away with just replacing the motor, but I'm leaning towards replacing the whole pump. I suspect the pump is pretty old and has had at least one replacement motor already. The problem I have is the pump model number is no longer legible and I don't know exactly which pump to get as a replacement. I am including some pictures in hopes that someone can help me identify which pump I have so I can just purchase an exact replacement. I think it is a Hayward Super Pump 1 HP, however when I look at buying that pump it is listed as having 2" ports and my plumbing is 1.5". Is it possible my current pump is still the 1 HP Super Pump but the current 1 HP Super Pump has changed to 2" ports? I'd appreciate any help with deciding which replacement pump to purchase. I'm comfortable doing a little bit of plumbing work, but I would like to avoid a major reconfiguration job which is why I'd like to replace with a same/similar pump.
Loris
Loris
