When running normally my pump is around 12psi. When I connect the bot to my return, I have to turn back the flow rate and turn on the fountain, else the bot becomes an airplane. When I do this the pressure is just under 20psi. Just want to make sure the Hayward pump can handle this pressure for extended periods of time as we tend to leave the bot in the pool if it is not being used.
