- Sep 22, 2011
- 211
I've had an ongoing issue where the pressure in my DE filter will slowly rise over the course of a week or two. When I backwash, the pressure goes back to normal, but then in a week or two goes back up gradually. Normally, my PSI after a backwash is about 10 psi or 11 psi. By about a week or two, it's up to 20 psi.
I had a suction side leak at a jandy valve, that I have since replaced. Before replacing the valve, I assumed the problem was due to air getting into the filter, causing the pressure to rise. I now know there is zero air getting in the suction side, based on the fact that I have no bubbles in my skimmer basket, the skimmer basket stays fall when the pump is off and does not lose prime, and when I open the bleeder valve on top of the filter I get only water and no air.
My chlorine levels are good and I have zero CC. The water is crystal clear and looks great.
I can only figure that something is clogging the filter but I can't figure out what. Any help?
