Posted this same problem about 4 months ago and thought I had it figured out by R&R the filters, but problem back again.
Here's what I have:
Pentair 4 cartridge filter system
Pentair Pump
Issue: After R&Ring filters a few months ago, pressure was right where it was supposed to be after swinging from 0-30 psi.
Noticed yesterday the water was hardly moving; pressure at 30 psi.
All I did was shutoff pump, open relief valve on top of filters and let it drain internally for a few seconds, closed valve and restarted pump.
Pressure then at 10 psi.
Shutdown and cleaned filters which weren't dirty at all JIC.
Then pressure came up to 15 psi.
This morning, sitting at 0-1 psi.
Have moved all valves to different positions.
No bubbles in return water.
Lost again on the huge swings of psi when not doing anything.
Here's what I have:
Pentair Pump
