Had this pool for almost two years now and it NEVER seems to constantly work. I posted every picture I could think of to take. The main issue is I never seem to get consistently smooth pumping of water. At some point the filter will fill with air and the only thing that seems to “reset things” is to turn it off, bleed the air, and empty the strainer (even though there’s rarely a lot of debris). And then, depending on the configuration of the levers, its a matter of days or hours (sometimes minutes) before I have to repeat the process. Often times if I have the strainer open and bleed the air, the strainer overflows, which to me says there’s a blockage somewhere but again, it’s never consistent.
How the levers are set tends to contribute to how often this happens:
*skimmer on full, floor/vac off - this is when I have the fewest issues. Sometimes I can go a week or two without issues but the second I turn the vac or floor on, the pump begins to get loud and lose prime.
*skimmer on half, floor vac, or floor/vac - lucky if I get 15 minutes without a problem.
there doesn’t seem to be any difference to whether or not the solar bypass lever is on or off. I used to think having the bypass on resulted in fewer issues but recently that doesn’t seem to be the case.
usually when I have to “reboot” everything I get large bubbles from the inlets, but that goes away after a few minutes.
WEATHER - here in Las Vegas we get periods I’d pretty strong winds, and when the wind is blowing strong (20mph+) I basically can’t even use the pump, all the stuff above happens in a matter of minutes regardless of the configuration. normally id think the wind is blowing debris into the skimmer But the skimmer is rarely full.
WHATS BEEN DONE SO FAR:
*recently replaced the filter cartridges and the o-ring
*replaced o-ring and cover for strainer
sorry for rambling but I’m at my wits end with this stupid thing and I wanted to give as much info as I possibly could.
Help!
Help!
