I have a variable speed pump. It works when the system is on the pool mode. However, I noticed that it doesn't work when I switch the pool to spa mode. I checked the two valve actuators: they operates correctly and do switch from pool to spa mode when I turn on the spa mode. But the pump doesn't run and no flow on this mode. I tried and powered the pool equipment breaker off and on in our electrical panel in the garage, but it doesn'tolve the problem. I would appreciate it if anyone could help me fix this. Thank you in advance.
