You want to add it under filter pump nothing else. It could be something else wrong with the pump itself. Does the breaker stay on after you flip it. You can try stand alone mode to see if it works by doing the 10 minute off cycle again and flipping the 1st dip switch back up and reconnect the wires that are inside the pump and disconnect the com wires that run to the omni
Yeah my pool guy surprisingly called me and told me to try it manually. Sadly that didn’t work. Guessing I have a pump issue. He’s supposed to come Check it out when he gets home from vacation. Thank you very much for all of your help and insight! It was greatly appreciated!
